Home
Community
Discussion Forums
Most Active Hardware Boards
Machine Vision
Topic
Machine Vision
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
I have recently started using the IMAQ add-ons in Labview 6i.
danwebb
Member
05-18-2001
08:59 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Does anyone know if I can easily (and if so, how?) convert a 16bit image to RGB format (or vise versa) without re-opening it?
Dan
0
Kudos
Message
1
of 3
(3,627 Views)
Reply
Re: I have recently started using the IMAQ add-ons in Labview 6i.
BruceAmmons
Trusted Enthusiast
05-18-2001
10:10 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Dan,
I believe you are looking for "IMAQ Cast Image" under Image Management, which will convert from one image format to another. The help information should be enough to get you on your way.
Bruce
Bruce Ammons
Ammons Engineering
1
Kudo
Message
2
of 3
(3,627 Views)
Reply
danwebb
Member
Author
05-18-2001
10:41 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Bruce,
I knew it would be simple! Thanks, exactly what I was after.
Dan
0
Kudos
Message
3
of 3
(3,627 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
