Machine Vision
IMAQdx camera not found
I have a camera configured in MAX with the correct .iid and .icd files. I have the interface name of the camera, serial number, manufacturer, etc.
When I try to find cameras in my own application, it returns no cameras found (imaqdx.EnumerateCameras). When I try to open the camera with the interface name, it returns that the camera is not found (imaqdx.OpenCamera).
I am using MeasurementStudio.Net with Vision Acquisition 8.5. The frame grabber is PCI-1422.
(4,146 Views)
Accepted by topic author rhollen
For the 1422, you need to use the IMAQ (no dx) acquisition routines.  IMAQdx will not work, since it is for firewire, USB, and GigE cameras.
Bruce
Bruce Ammons
Ammons Engineering
(4,144 Views)
