Machine Vision
Instability in pattern matching
i have changed rotation as you said it. But i can not find all of the patterns (it must be 4)
Message 41 of 117
(3,875 Views)
Wait I will generate and attach a vi for you
Message 42 of 117
(3,874 Views)
Check this
Message 43 of 117
(3,862 Views)
Hallo Muks, first of all, i thank you for your answers. But ... ( :-)) )
- I don't need vi. I can easyly check in Vision Assistant if pattern matching, geometric matching, template for an image works. There is no difference in vi results and Vision Assistant results.
When i use your template finds pattern matching all pattern and when i use my template ( just pattern matching, "template_desa.png") finds pattern matching just 3 of them.
And again, as my first message in this topic: geometric pattern matching is not stabil. Is there any chance for a solution? I ask this questions of course NI.
Message 44 of 117
(3,857 Views)
Dont have labview right now but as far as I have checked this looks like a bug
Message 45 of 117
(3,849 Views)
I'm new here in the forums and i don't know who and how should I contact about the issue. Apparently no one from NI is interested in the topic.
Message 46 of 117
(3,844 Views)
Dont worry I have contacted NI and we will hear something soon.Smiley Wink
Message 47 of 117
(3,838 Views)
Muks: Thank you very much for your interest and your helps. Can i ask you a question? For which one have you contacted NI? Pattern Matching and/or Geometric Matching? In my opinion both pattern matching and geometric matching have stability problems. Our project is based on this functions.
We've spend a lot of time until we find this errors/bugs/problems. And this makes me angry.
Message 48 of 117
(3,828 Views)
As I said earlier i didnt find enough time to confirm this with geometric matching. I will definetly post my findings here. I have asked "bluechese" (NI enginner) to have a look in this thread .  We will solve this dont worry
Message 49 of 117
(3,825 Views)
Edit :Double post
The forum is irritatingly slow today....Smiley Mad
Message 50 of 117
(3,823 Views)
