Machine Vision
Instability in pattern matching
For both picture use i same settings in geometric matching. Results are but different.
Message 31 of 117
(3,567 Views)
What is the rotation setting that you have kept it in pattern matching. I will post you the vi that works.
Message 32 of 117
(3,565 Views)
- With pattern matching get i even worse results. You see it "pattern_matching_results.png"
- Template file is bit because after i with geometric matching psition and rotation angle find, use i same templae for golden template. My templates have:
 (1) Patttern matching (in case of i need)
(2) Geometric matchin (edege based & feature based)
(3) Golden template (for finding defects)
Message 33 of 117
(3,564 Views)
i forgat the screenshot.
Message 34 of 117
(3,563 Views)
Thank you. But that doesn't explain why is geometric matching instabil or gives false results.
Message 35 of 117
(3,561 Views)
The template that i am attaching works for both the images but i am still not sure why the template that you chose didnt get detected. Looks like a bug to me.
Message 36 of 117
(3,555 Views)
In the screen shot you are checking only for +/_90 deg and not 180
Message 37 of 117
(3,552 Views)
Muks: when i use your templae get i these results: "results_for_muks_template.png",
But when i an another template (just for pattern matching "template_desa.png") get again different results for same settings ("results_for_template_desa.png"). And i can't find all of the patterns.
And again, all of them doesn't explain, why i get different results from geometric matching for same images.
Message 38 of 117
(3,551 Views)
I agree. I thing there's is a bug (ore in pattern matching/Geometric matching). I can give you a lot of examples. Often get different results for same images.
Message 39 of 117
(3,547 Views)
As i mentioned earlier you are still checking only for +/- 90  degrees. Change it to 180
Message 40 of 117
(3,545 Views)
