Machine Vision
Is vision development module in labview 8.6. sufficient for real-time image acquisition and analysis using a webcam
I'm new to labview and trying to develop an eye-tracker using labview 8.6. It has the vision development module and i was wondering if this was sufficient for real-time image acquisition and processing or would i be needing any other software tools.
Message 1 of 8
(5,370 Views)
Hello, certainly it is possible and sufficient for real-time tracking!
About eye tracking - if you need an example, you can find the code here:
https://decibel.ni.com/content/blogs/kl3m3n/2013/10/08/real-time-face-and-eye-detection-in-labview-u...
The code uses OpenCV functionalities along with the LabView UI (and some other functions like overlay).
Hope this helps a bit.
K
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Message 2 of 8
(5,367 Views)
Thank you
I read at some sites that they also used vision acquisition softwares like NI-IMAQ to capture images from the webcam ........is this necessary?
Message 3 of 8
(5,361 Views)
Accepted by Prathiksha
Yes, to acquire images from a webcam you would need imaq-dx drivers.
Take a look at this link:
http://digital.ni.com/public.nsf/allkb/0564022DAFF513D2862579490057D42E
K
Message 4 of 8
(5,357 Views)
Thank you, it really helped.......
Message 5 of 8
(5,351 Views)
I' ve tried to install Labview 8.6 on my laptop but it's sounding an error and people are telling me that it's a problem with my OS and it's not supporting . I'm using a Windows7 64-bit system.......can anyone help me with this....?
Message 6 of 8
(5,327 Views)
I have 32-bit LabView (2013) installed on 64-bit Windows 7 operating system. Everything works without any problem. I also had LV 2011 and 2012 installed on 64-bit operating system.
The release notes for LV 8.6 show that it works on Vista, so it should work on Win 7 also. Try copying the entire contents of the disk(s) on your PC an install from there.
K
Message 7 of 8
(5,320 Views)
Hey Thank you. I finally got it installed althoughi  had to do it manually.....took me almost the entire day but was worth it.
Message 8 of 8
(5,280 Views)
