Machine Vision
Issues about the web management of IC-3172 (Silverlight 5.1.50918.0 + Windows 10 Pro v1903 update)
Sine the W10 Pro v1903 update, it's impossible to access to the Web Management window of my IC-3172 in NI MAX (v19.0).
The following windows appear :
First messageFirst message      Second messageSecond message
I tried to uninstall/re-install Silverlight, idem with the NI MAX restauration...
Does anyone have a solution?
Thank you in advance !
(2,249 Views)
There are issues with NI-Max when upgrading to Windows 10 + silverlight.
If you have already tried to uninstall/re-install silverlight, would you mind following the steps in the solution section of this article please:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OPRSA2&l=fr-FR
Alexandra Falkiner Andrews
National Instrument, Technical Support.
(2,155 Views)
But, this process doesn't work in my case...
I tried to repair also my installation of NI MAX (and other NI softwares) but the result is the same...
Best Regards!
(2,077 Views)
