Machine Vision
Labview 8.6 USB Camera Problem
I'm kind of new to LabView.  I am working on an image processing project, but I am having problems with LV and USB camera.
I've installed the NI_IMAQ for USB file, I have the NI Vision module.  I've read the "NI-IMAQ_for_USB_Camera_User_Guide", but I cannot find what the figures are using (fig. 6).  I imagine the writer might have used a slightly different version of LV, but I cannot find anything in my icon palette that has a "USB Grab Acquire".
When working wih the Vision Assistant, I am able to caputre images from my USB camera so I know it works, I just cannot get it set up as a VI.
Is there an uptodate User Guide or does anyone have an guidance?
Thank you for your time,
-Rocky
(5,567 Views)
Hi, Rocky,
Read this:
Installing NI-IMAQ for USB on LabVIEW 8.6
Did you tried this procedure for installation?
Andrey.
(5,562 Views)
No I had not seen that before now.
I looked for those files, but my LabView was a fresh install and I do not have previous versions.  😞
Thank you for your response!
(5,553 Views)
Accepted by RockyG
Hi, Rocky,
Attached the files, which you're looking for...
Andrey.
(5,551 Views)
AWESOME!
You, good sir, are my hero.
Thank you,
-Rocky
(5,545 Views)
