Machine Vision
Measure distance between 2 glare points
Does anyone know how to measure distance between 2 glare points (Image attached). The image shows 10 sets of glare points. I appreciate if you can guide me to process the image and produce algorithm to detect this 10 sets of glare points and measure the distance of each set.
Farid
Message 1 of 8
(5,512 Views)
Question time
1. Do you want to measure like 1 to 2 to 3 to 4.....10 (IF yes which is 1,2,3)
2. Do you want to measure distance of each from each other?
3. From where do you want o measure? (Centre? Anywhere and keep that for the rest do that it calibrates when it finally matters?)
Message 2 of 8
(5,511 Views)
Accepted by MFarid
check whether this will do
Message 3 of 8
(5,508 Views)
Hi muks..
thanks for your reply.
Question time
- No. The image has 10 sets (doesn't matter which is 1,2,3..). A set has 2 points, and I want to measure these 2 points.
- I want to measure distance of each set (consist of 2 points only). So, there will be 10 different distances.
- Anywhere
Message 4 of 8
(5,507 Views)
And did you check the vi i attached? helped?
Message 5 of 8
(5,492 Views)
Thanks for the glare.vi.
That is the solution that I'm looking for.
I think,  I've an idea how to measure the distance between 2 points based on your glare.vi. I will add the particle analysis bounding box (Top,Left,Bottom,Right) and I will apply the same technique that you send me on fringesl.vi (http://forums.ni.com/ni/board/message?board.id=200&thread.id=25165). Then, I will use IMAQ Point Distance to measure between 2 points.
Thank you very much.
Farid
Message 6 of 8
(5,488 Views)
Way to go. Post back if you are stuck
Message 7 of 8
(5,434 Views)
I managed to solve the problem by following the method that I've explained before. Thank you very much for your help.
Message 8 of 8
(5,430 Views)
