Machine Vision
Missing attributes (Gain, Ref. Voltage) in JAI Pulnix TM-6740 CL camera file
I am using a NI PCI 1428 interface with the mentioned camera. My problem is that the corresponding icd-file available does not support all attributes that I would like to modify within LabVIEW 8.2.1. In particular, it does not contain any reference to Gain values or Reference Voltage.
My question now is: how can I address and adjust these parameters if they do not appear in the camera file? Has anybody come across an updated version  of the icd-file which does contain these attributes? Or this there another way for me to attack the problem?
Any help will be much appreciated!
Cheers,
Benjamin
(3,416 Views)
can you tell us the exact icd file u r having? DO u feel ur icd file is corrupted?
(3,346 Views)
The camera file available is "Pulnix TM-6740 (1428).icd" (version 6.00), which supports only some of the camera attributes. However, in the meantime I have been able to create a customized expanded version of that file using the "NI Camera File Generator" tool, which proved to be pretty useful.
Hence the problem can be considered as solved.
Thanks anyway,
Benjamin
(3,342 Views)
