Machine Vision
NI1439 16-bit signed display imagery: Just fix it
John,
Did you simply want to "cast" from I16 to U16? If so, you can try my hacky VI here: http://forums.ni.com/ni/board/message?board.id=200&message.id=26375#M26375 . It will do the cast effectively free, since it is merely a reinterpretation of the same data.
Proper U16 support in the NI-IMAQ driver (where the camera file/attributes can specify the data as signed or unsigned) is expected to be in the upcoming release.
Eric
Message 21 of 22
(1,136 Views)
Eric
Hi, Eric,
"Proper U16 support in the NI-IMAQ driver" makes no sense without proper U16 support in the whole VDM. I waiting this feature for years, and it still not here. I guess that probably I'll develop my own Image Processing toolkit faster than NI does U16 support for all functions where I16 supported. 😉
Andrey.
Message 22 of 22
(1,125 Views)
