Machine Vision
Need help : IMAQ IFFT showing error
while executing Inverse FFT an error pops up.Please  help me  by possible solutions. Thanks in advance...
(6,021 Views)
If you are doing an inverse FFT, the input image has to be Complex Single.  It won't work with other image types.  Are you sure you don't want the FFT instead?
Bruce
Bruce Ammons
Ammons Engineering
(6,016 Views)
Hi Bruce, Thanks for your reply..
I tried IMAQ FFT and showed no error. But in my code I have to take the Inverse Fourier Transform of the Image( converted frm the array as shown in th image). Using FFT for IFFT is a Right soln.
(6,006 Views)
Accepted by sree99
If you need the inverse FFT, then use the inverse FFT.  I just wanted to make sure you had the right function.
Change the type of your input image to Complex Single, and it should work.
Bruce
Bruce Ammons
Ammons Engineering
(5,998 Views)
Thnx Bruce I got it right..
I have 2 more questions
1) The array (2D) multiplication I did in the pgm is correct?? or I have to go for matrix multiplication
2) How to input an image to math script?
(5,977 Views)
the basic multiplication is performed element-by-element whereas the matrix operations are different.
To use the mathscript node, please see the image below:
Note that mathscript nodes are slower than native functions or .dll's.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,969 Views)
THNX  klemen!!
(5,945 Views)
