Hello again liaw82,
Thanks for explaining the clustered histogram. I now have a much clearer idea of what you are working with.
Without knowing more about your application, and the algorithms that are associated with it, I may not be the best resource. In most applications I have dealt with, it is possible to normalize data by dividing the set by the maximum entry. In those situations, the distribution being Gaussian was actually a property of the data. This wasn't something that we could cause without ruining the data.
That said, this type of data manipulation is not my expertise. If you are working on this as a project, I might recommend asking for assistant from whomever has created or selected your processing algorithm.
Good luck,
Robert
