Machine Vision
Odd Image Behavior
Hi Steve,
I can't seem to find anything wrong with the Image Acquisition VI.  Could you explain what the purpose is of the portion of the code where an array is initialized with the image and passed into the For loop?  I couldn't seem to figure out what this was doing.
Also, have you checked the intermediate images as Bruce suggested?
Rishee B.
Applications Engineer
Message 11 of 12
(1,230 Views)
Hey Bruce and Rishee,
I'd like to thank the both of you for your help over the past 2 weeks.
Bruce,
1) I checked the individual image sizes and they were all 1280 x 960 (Video Mode 27)
2) The number of images was correct and they are named in order they are taken (1, 2, 3...)
By changing the video mode and seperating the acquistion and combination processes I am getting full and correct images as expected.  The entire array is 14080 x 11520, the fashion of 1280 x 960 images, 11 across and 12 down.
Rishee,
That portion of the code was from the earlier versions of my VI and I simply never took it out.  Can't hurt to leave it in there Smiley Tongue
Once again, thanks to the both of you my imaging process is no longer an issue.
Message 12 of 12
(1,216 Views)
