Machine Vision
PCI-1409 with Single Board Computer and Backplane
Having had difficulties acquiring images with a single board computer and backplane with my PCI-1409 system, i am wondering if someone can suggest to me an SBC and backplane (with two PCI slots), which will work with the system,from previous customers experience.
Please don't suggest what was wrong because i spent several months trying everything and dealing with NI application engineers considerably and also discussion forums . The SBC had a PCI bus bandwidth limitation.
It would be a huge advantage if the SBC also had onboard voltage regulation, and could be supplied from unregulated 12 volts (and available in the UK)!
Thanks in advance,
(3,107 Views)
Sorry, but this instead of an answer is a question that I wish him to carry out:
I am working with a PCI-1407 card and a SBC and I have the same problem that you, it would be so kind of telling me if you have found some SBC with which the operation of the PCI-1409 is correct. With the SBC that I have proven it works bad as in your case.
Thank you.
(3,107 Views)
