Machine Vision
Problem in image acquisition
I'm using a Hitachi ccd , which worked fine until yesterday, suddenly I have an error "IMG_ERR_VLCK - can't lock on video source (error 1074397153)" appearing everytime I press acquire,
the cable looks fine so does the pins, the dc is also ok , I don't know what happened
I tried the solution written in the common errors, and still nothing.
can anyone help me please ?
(4,108 Views)
Accepted by Dalia12
Hi Dalia12,
I see you have already found: http://digital.ni.com/public.nsf/allkb/3434173630CBC97686256F8000536593#1
Which has multiple troubleshooting techniques.
As it has worked before, have you installed any new drivers or made any changes to the settings of the camera file or the camera itself? If not, it may be a hardware issue in which case do you have another camera, frame grabber, or cable to test?
DylanC
(4,096 Views)
well I haven't installed any new device , but the computer is a little bit old and most probably have a virus or a trojan, do u think this could be the reason??
thanks for your help
P.S I clicked the accept as solution by mistake how can I undo it ??
regards 🙂
(4,080 Views)
Hi Dalia12,
I'm not sure if a virus could be the reason, do you have another computer you can try?
(4,070 Views)
