Machine Vision
Reducing image size
A relatively simple question. Using CVS 1456 and a Basler Camera A622F with VBAI 3.0, how can i reduce the size of the whole image while grabbing a frame from the camera via an external trigger? For example, if the actual matrix size from the camera is 1280 x 960 pixels, how can i reduce it to 640 x 480 pixels during frame acquisition while still looking at the same area/image, but ofcourse with a smaller image size (or lesser pixels per square mm)?
The reason i am asking this question is that while applying the existing script in VBAI, the loop time does not allow my application to go beyond 20 parts per minute. I need the same script applied on a smaller image so that it takes less time to run, thus increasing the part throughput. I am sure i will lose some details while doing so, but i think this will be an acceptable trade-off for my application. I have tested this (using benchmarking) between large sample images and 40% reduced size of the same images. It takes much more time using the same script on the large images compared to the smaller ones.
Does the camera tool (Format 1 Mode 2 etc.) help in this case? I will also appreciate If you have any other ideas / comments about dealing with this problem.
(3,521 Views)
I am pretty sure what you want to do is acquire the full resolution image, then use IMAQ Extract to reduce the size of the image.  Using a step factor of 2 for both axis will reduce your image to half its original dimensions.
Bruce
Bruce Ammons
Ammons Engineering
(3,515 Views)
Accepted by Medianix
Thanks for your response bruce. But my version of VBAI 3.0 shows Geometry tool that has a "resample" option. The problem was solved by chosing a smaller resolution in it.
Have a great day.
(3,502 Views)
