Machine Vision
Select Inspection issue in VBAI 2018
Dear Team,
I am facing issue in Inspection Selection in VBAI 2018.
In version 2012, it is working fine.
I prepared two test Programs (0 and 1) with only match tool.
In select Inspection, there are one user Input tool and one Select Inspection.
When I click on the button (based on user input), inspection switching is not happening.
Could anyone please suggest what I am doing wrong or its due to some bug (Hopefully Not).
I am also attaching some screenshots for reference.
(2,313 Views)
Accepted by JN_23
This is a known issue that was fixed in VBAI 2018 SP1:
https://www.ni.com/en/support/documentation/bugs/18/ni-vision-builder-ai-2018-and-2018-sp1-bug-fixes...
705501 Select Inspection State does not switch between inspections when using previous measurements
Try updating to VBAI 2018 SP1 or VBAI 2019.
Hope this helps,
Brad
(2,283 Views)
Thank you Brad for the information.
Thanks and Regard,
N
(2,184 Views)
