Machine Vision
Unibrain Fire-i color camera with IMAQdx
Hi All,
I am considering purchasing a Unibrain Fire-i 785c color camera. Is it possible to acquire from this camera using NI-IMAQdx (I do not have any NI-VISION). The sales rep pointed me at a quite expensive third party SDK. However all I want to do is snap images to a file so this seems like overkill......
Can anyone advise?
Many thanks,
David
(3,216 Views)
Accepted by DeltaJ
Just to take images, you need the IMAQdx (Image Acquisition Drivers), which is a few hundred dollars.  That should be all you need if you aren't processing the images.  If Save Image isn't available without NI Vision, you can convert the image to an array, then save it using the picture control tools.  It takes a few more steps and probably a little more time, but the price is right.
Bruce
Bruce Ammons
Ammons Engineering
(3,215 Views)
Thats what I needed to know - many thanks for the information Bruce,
David
(3,208 Views)
