Using Vision Builder for Automated Inspection 2.6, when I select Run LabVIEW VI, and select a LabVIEW VI Path to use in the inspection sequence, I get the following error window:
VI Path is Invalid
There is no VI at the path you specified
"OK"
I am using LabVIEW 8. Is there a problem with LabVIEW 8 and VB4AI 2.6, or is there some requirements about the VI prior to trying to load it in VB4AI.
Anybody with any knowledge would be gratefully appreciated.
