‎09-13-2012 04:23 PM
I'm using the IMAQ Video Out Display Mode VI (http://zone.ni.com/reference/en-XX/help/370281M-01/imaqvision/imaq_video_out_display_mode/) to display images on a PXI-8110. No matter what Screen Area I choose, I seem to be getting 640x480. Any ideas on what I'm doing wrong?
Kevin
‎09-17-2012 11:47 AM
Can you show a snippet of code showing how you are setting the video mode (and the constants you are setting it to?). Also, did you check the error output from that VI? Note that it is possible that certain refresh rates might not be supported (due to the monitor you have attached) and that might be the source of the error.
Eric
‎09-17-2012 11:50 AM
‎09-18-2012 08:31 AM
Hi kevin.key,
Can you post a screenshot or the section of code where you set the video out display mode? Are the settings saved on the Video Mode Out terminal if you select Get(False) after setting the resolution?
DylanC
‎09-18-2012 08:32 AM
‎09-18-2012 08:53 AM
‎09-19-2012 10:58 AM
Hi Kevin,
Have you verified it is going through the correct FPGA case? I see that you use the same Display Type as the selecter for each case in your flat sequence, but one is FPGA and the other Custom Device, do you not have a Custom Device case in the first sequence where you set he resolution so it defaults to FPGA?
DylanC
‎09-19-2012 11:11 AM
‎09-20-2012 08:13 AM
Hi kevin.key,
Can you wire a constant in the second case structure to the IMAQ Video Out Display Mode with the correct resolution just to make sure? Can you also change the order of VI's and call the IMAQ Video Out Display Mode before the IMAQ RT Video Out.
Let me know if this still doesn't work.
DylanC
