Machine Vision
Vision Assistant fails to generate LabVIEW code
Apologies for the very long delay in responding. . .
If I recall correctly (it has been a while!), a new release of the vision software came about shortly after I had this problem, and I installed that which resolved the issue.
If I remember differently, I will post an update.
Richard
Message 11 of 13
(1,384 Views)
Hello all,
I'm running into the same issue. It was working just fine and than it failed to create a Labview VI. It directs me to the MyOutput file.
I'm using Vision Assistant 7.1.1 and Labview 8.0
Please advice if you can.
Juergen
Message 12 of 13
(1,264 Views)
If you are using LabVIEW 8.0, you need to use Vision Assistant 8.0 or up. Anything below 8.0 will not give you the desired result.
Jaidev
Senior Product Manager
Message 13 of 13
(1,248 Views)
