Machine Vision
Vision acquisition software, library activation
I am having a problem and I would be very grateful if you kindly help me through. I have labview 2011 installed and licensed on my pc, I also installed the ¨vision acquisition software¨ from the Divers CD. Now after a while the vision acquisition library has stopped working and ask for activation. I have bought the vision acquisition software separately and I have the activation code, but I could not find a way to activate the installed library on my pc. I would appreciate if you kindly respond at your earliest convenience.
(5,543 Views)
Accepted by RUphysiology
try locating and running "C:\Program Files (x86)\National Instruments\Shared\License Manager\Bin\nilmUtil.exe".
(x86 on my computer!)
This is the license manager, where you can activate your license. Right click on "Vision Acquisition Software" and activate. Follow the instructions.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,541 Views)
Worked just fine. Thank you very much
(5,537 Views)
