09-06-2012 04:03 PM
I have some RS170 cameras that I need to interface with, but the problem is that I can't find a framegrabber for I vision that is not obsolete. Do you still support any? If not, are there any digital solutions with converter boxes that can be used? If it is Firewire(Ethernet or USB), will vision work with a port already on the PC mother board?
09-07-2012 02:38 PM
Hi Steve,
Unfortunately we no longer have support for any analog framegrabber solutions, with that, there may be converters available but I'm sorry to say I don't personally have any familiarity in using them. Firewire, Enet, and USB cameras will work with your PC as long as they follow the proper protcols (DCAM, GigE, and DirectShow respectively). Sorry I don't have a better answer for you with your RS170 cameras but I hope this helps!
