Machine Vision
Where can I find the property "Vertical Mirror"?
Hello
I do have an USB camera connected which shows the image in the wrong rotation. Under Max there is a parameter in "Acquisition Attributes" -> "Vertical Mirror" which can be set to True.
How can I set this parameter under LabView? I can not find it under the properties.
thanks in advance
(4,036 Views)
I don't think you can set it as an acquisition paramter in LabVIEW, but you can flip the image once it's been acquired (use the IMAQ Symmetry.vi function in Vision & Motion > Vision Utilities > Image Manipulation palette)
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(4,035 Views)
Accepted by Norick_17
  In IMAQdx, you usually refer to properties by specifying them by string. See Programmatically Get and Set Attributes with IMAQdx
To get a list of supported attributes of your camera, call "IMAQdx Enumerate Attributes".
(4,029 Views)
this was exactly what I was looking for!
Thanks for the help..!!
(4,024 Views)
Nice to hear this.
You are welcome.
(4,021 Views)
