Machine Vision
camera found in MAX, but will not accept correct camera file
Hello.
I am using a Imperx 210L camera with a PCIe 1427 camera link board.  MAX sees the camera, but does not allow me to choose the correct camera file.  When I try, it says:
Error 0xBFF60135
The requested bit stream is not compatible with this device
However, if use the Imperx 1M48-LC camera file, MAX does not complain.  What could I be doing wrong?  I just reinstalled the VAS2009 package, to no effect.  Thanks in advance.
(4,045 Views)
(4,036 Views)
muks wrote:
refer here
Thanks, but the suggestions do not help.  I have installed the latest version of the vision acquisition software (VAS 2009).
I guess I will try and make my own camera file.  It is just odd that the camera file that is supposed to work with this camera fails so dramatically.
(4,018 Views)
Accepted by o2-
When I used an older version of the National Instruments camera file (v 5.7), everything worked fine.
(4,002 Views)
Hmmm thanks for updating
(3,974 Views)
