Machine Vision
camera suggestions
I am looking for a camera (monochrome/VGA) to acquire images at 60 fps(progressive scan). I have a NI-1409 Devise with NI-IMAQ image acquisition driver. The final goal is to obtain 4 sec movies. I'm looking for suggestions regarding cameras that could be used.
I have two cameras in mind SONY 8XC-HR60 and SENTECH-STC-1100. I would also like to find out if one has any advantage over the other.
Any suggestions would be appreciated
(3,002 Views)
I have not seen the SONY 8XC-HR60, did you mean XC-HR50? If so, both cameras are very similar. The frame rates and resolution are almost identical. The differences are going to be small things like shutter speed settings, etc.
(2,978 Views)
