Machine Vision
colour to grey scale and crack detection
how to convert a colour image to grey scale. also i want to know how to detect the cracks in the objects from their images
Message 1 of 15
(6,324 Views)
Accepted by saillesh
There are 3 planes involved in a color image. Each plane having values 0-255. By extracting any single plane you can convert the image to a grey scale one.
Try extracting the luminance plane (in color plane extraction).
Use vision assistant initially to get an idea.....
Message 2 of 15
(6,312 Views)
If the crack in really nicely different from the object then applying a proper threshold and removing small particles and going with a particle analysis will be enough.
But we need details.If you can post some images then I can suggest you a method
Message 3 of 15
(6,312 Views)
Use the vision assistant to start with ,as it will help you extract the colour planes and (also gives an option to convert your image to a grey image) as well as it will help you learn about other vision utilities which labVIEW offers . You can detect the cracks or edges by setting proper thresholds . Please describe your application in a little detail so that I can help you with a more precise solution.
Message 4 of 15
(6,306 Views)
Saillesh,
What muks suggested is a very practical approach. I personally implemented it with object filtering to detect cracks in an online ceramic plates inspection.
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
Message 5 of 15
(6,304 Views)
to convert a color image to gray scale you can average all three planes or you use different weights for the color planes. Typical weights are
30% red + 59% green + 11% blue
See also http://forums.ni.com/ni/board/message?board.id=170&message.id=422864#M422864
Message Edited by Jörn on 2009-08-12 12.08.2009 11:48 PM
Message 6 of 15
(6,291 Views)
i wan to detect the cracks in tracks of train .can i use fft for this . if any other soluion please help me
Message 7 of 15
(6,230 Views)
i have to inspect cracks in the train  tracks . is your method of object filtering is suitable for that ?.
Message 8 of 15
(6,229 Views)
Well posting a few sample images will do a lot of help. I mean there is no other way  we can suggest algorithms to use. We can only keep guessing.
Message 9 of 15
(6,227 Views)
im posting my pictures here  (with and without cracks),could u help me with the algorithms.i have taken fft for this, is there any option to get the strength of fft to compare the images?
Message 10 of 15
(6,169 Views)
