Machine Vision
conversion to previous version
      can you please convert the attached file from 2012 to their lower version.
Thank you
(4,526 Views)
Hi
These VI's can be converted into the lower versions but for them to work properly you need to have IMAQDx installed in your PC for those lower versions.
--Ninad
Ninad Regundwar
Junior Engineer | ARAV Technologies | www.aravtech.com
(4,508 Views)
Accepted by Madhubalan
Thank you
Converted to LabVIEW 8.0
By the way - please use Version Conversion Board for such requests
Andrey.
(4,503 Views)
