Machine Vision
digital image correlation vi
Dear expert
Is digital image correlation (DIC) algorithm for strain measurement implemented in Labview? If not,  does somebody share Labview vi for DIC?
I found that several free version of DIC in the web but, there is no Labview version.
Does anyone have any idea on this?
(7,401 Views)
Accepted by chulminy
Digital Image Correlation is not implemented in LabVIEW as part of a toolkit or module at this point. This may be something good to suggest on the LabVIEW Idea Exchange if you're interested.
Blake C.
www.ni.com/support
(7,384 Views)
Thanks for kind response.
Chul Min
(7,375 Views)
Digital image correlation (DIC) has proven to be very effective at mapping deformation in macroscopic mechanical testing, where the application of specular markers (e.g. paint, toner powder) or surface finishes from machining and polishing provide the needed contrast to correlate images well.
(7,144 Views)
