Machine Vision
dimension scale bar
Hi
Is it possible to add a dimension scale bar to an image acquired by labview? If so, could you direct me on how to acheive this?
(4,059 Views)
By dimension scale bar, do you just mean something that shows a distance and tells you how far that distance is such as we'd see on a map?
If so, are your dimensions known ahead of time?
I'd work with some logic to use the Draw Line VI to create the line you're interested in having.  http://zone.ni.com/reference/en-XX/help/371361M-01/lvpict/draw_line/
(4,042 Views)
