Machine Vision
for USB camera,The passed in sesssion or interface is invalid,why?
i wanna use USB camera to snap image,but i meet  the problem.i have these softwares:
and the error is:
and IN MAX the USB camera is in this position:
what's the matter?do i need more software to support the USB camera  such as LABVIEW RT module?In NI.com,there are only updates for RT module,what should I DO?
I really appreciate your help.thank you
(4,500 Views)
and in project explorer i can't find the USB camera
(4,498 Views)
Accepted by topic author tuming
Use IMAQdx instead of IMAQ!
And be sure that you have image in MAX.
Andrey.
(4,494 Views)
AS andrey has suggested use an imaqdx and check for proper interface name.
(4,492 Views)
(4,491 Views)
thank you andrey.it's done.really thank you.
(4,472 Views)
thank you too muks.
(4,471 Views)
