Machine Vision
Dark point between pixels
Hi
I am using frame grabber card PCIe-1924 with IMPERX camera which are completely setup for age in my lab. In my project, I need only capturing still images.
After I try capturing the image (or video), a number of dark pixels are appeared between each pixel (see picture). So, these dark pixels greatly reduce the quality of the images.
Do you know what they are and How can I remove them? I think it some simple setting can solve this problem easily.
Thank you so much
Soongv
(4,580 Views)
Looks like a bayer coded image
Check this and this
(4,577 Views)
I answered almost the exact same thing in another thread.
Please DO NOT post in multiple boards.
Shane.
(4,567 Views)
I have linked the other thread with this one. As shane as sugested please stick to a single thread and continue here.
(4,564 Views)
Thank you for the possible solution. You maybe right about monochrome or color camera. I have to check the whole system again.
Sorry that I have posted on another boards. Actually, this is my very first time visiting here and I try to remove another one.
Soong
(4,550 Views)
Now that they are linked no problem. Post back if you are still stuck.
(4,548 Views)
