Machine Vision
gigE camera - Attribute out of range 0xBFF69012
I can see the camera using the Basler viewer software. I can also see the camera in MAX if I keep clicking on the GenICam source icon, which also appears in parallel with the scA1390_17gm icon in devices/imaqdx although the camera mode seems odd and the packet size is set to 0! This doesn't seem right to me. Initially when you click on the GenICam source icon a red cross appears, but if you right click and try again you can access the camera. All very puzzling.
Any help would be greatly appreciated.
LightWorker
(4,645 Views)
Just  a brief update on this. My problems seemed to disappear when I uninstalled the March 2010 version of the image acquisition software and installed the November 2009 version. Everything behaved just as it should. Another PC (running windows 7 64 bit) had exactly the same problems with the March version. I am now going to uninstall this and try the previous version. All my PCs running earlier versions of image acquisition seem to work fine.
(4,622 Views)
Accepted by LightWorker
LightWorker,
Have you tried the August 2010 release? There was a combination of items (updates to the Basler firmware and updates to the third-party GenICam component) that could cause incompatibilities that were addressed in this release. One of the issues potentially affected the Scout and Pilot series with firmware version 3.2-x and 3.3-x. Newer firmware versions form Basler should fix this as well, but later IMAQdx versions also work around the issue.
The grabbing the August 2010 release here:
http://joule.ni.com/nidu/cds/view/p/id/2137/lang/en
Eric
(4,607 Views)
Eric,
The Aug 2010 release seems to work fine - thanks for the tip. I didn't know there was an August release.
Regards
LightWorker
(4,592 Views)
The same happened to me with VAS August 2010, Windows 7 x64 and a sca1390 camera with 3.3-1 firmware.
What has worked for me: reinstall VAS August 2010, but without the 64bit GEV driver support.
Bye
(4,240 Views)
