Machine Vision
how can I use Imaq usb to get a snap image, get template and do pattern matching?
I try to track the braiding point. At first snap and grab a image to build the template. And I will grab a image every 5 seconds and compare with the template in order to get the position offset to control motion.  Please find the attached VI. It always calls the ' IMAQ Vision: (hex 0xbff60453) incompatible image type. how can I do? THKS!
Message 1 of 15
(5,956 Views)
It is most likely because of the imaq create not being compatible. Can you post a screen shot of the vi as i have lv 8.0?
Message 2 of 15
(5,951 Views)
Thank you for your replying. I attached my code by PDF file. It pretty much likes the example "Pattern Matching example".
Message 3 of 15
(5,932 Views)
Sorry, the last code need a little change. Only a image display was covered by case structure.
Message 4 of 15
(5,910 Views)
Hi Guang,
I think you are using two different bit depths in your image processing.  You will need to convert one of them in order to do what you desire.
Stephen Meserve
Message 5 of 15
(5,897 Views)
I recognized the problem. I didn't figure out how to convert them now. I'm new user for this. Would you please give me some clues?
THKS!
Message 6 of 15
(5,887 Views)
Hi guangli,
Use the typecast VIs.
Stephen Meserve
Message 7 of 15
(5,884 Views)
Thank you again. I used IMAQ cast. I doesn't work. I may something else wrong. Would you please help me see the code I attached before.
Message 8 of 15
(5,876 Views)
Message 9 of 15
(5,875 Views)
Message 10 of 15
(5,874 Views)
