Machine Vision
how to calculate frame rate required when I need to scan surface of 1meter moving at 0.5 meter/second
I need to scan a moving object surface with a camera.
My question is: Surface area of object is 1 meter in lengh and my camera frame size is 2048*2048 , so what is the frame rate I need ?
My mapping is 1 mm = 10 pixels
so 1000 mm = 10000 pixels
Is is like 10000 pixels / 2048 pixels = 5 frames approx?
Is it right way to determine the frames/second ?
Thanks in advance
Message 1 of 9
(9,343 Views)
Can you use a linescan camera for your application?
Message 3 of 9
(9,336 Views)
Thanks for the reply.
A good Line scan camera cost more and do not fit in my requirement as far as cost is there.
Message 4 of 9
(9,334 Views)
I have seen the link you suggested and it gives idea on band width calculation.
My question is 5 fps is sufficient to cover the surface I want to scan? or I may miss some surface area or some over lap may happen ?
Message 5 of 9
(9,330 Views)
What is the speed in which the object is moving?
Message 6 of 9
(9,324 Views)
object is moving at 500mm per second.
and the surface area I need to scan is 1  meter. In my knowledge, If I will scan with 50 fps I will get 50 frames (mapping is 1 mm = 10 pixels)
but I will get frames which overlaps each other, to get unique frame I need to set 5 fps.
This is just my understanding and I am new to machine vision. so correct me if I am wrong here.
Message 7 of 9
(9,322 Views)
Accepted by Nimish79
You are confusing your frame rate and your total number of frames.
Frame rate:  Speed is 500 mm/s.  Each frame has 200 mm in it.  500 mm/s / 200 mm = 2.5 frames per second.
Number of frames: Length is 1000 mm.  Frame is 200 mm.  1000 mm / 200 mm = 5 frames.
So you need to take pictures at 2.5 fps for 2 seconds to get 5 frames.
Of course, this is assuming no overlap.  In practice, it is a good idea to have a little overlap so you don't have any defects right at the edge of your image.  This is also assuming you can move your object at exactly 500 mm/s.
Bruce
Bruce Ammons
Ammons Engineering
Message 8 of 9
(9,312 Views)
Thanks Bruce,
This clears my doubts and I have got my answer.
Message 9 of 9
(9,310 Views)
