Machine Vision
how to enhance the orange color ?
First of all dont rename bmp file to .jpg. Downloading it is a real pain.
Message 11 of 14
(1,139 Views)
Definetly i will not suggest you to go with the suggested particle removal. You can reduce the iteration and filter it with particle filter instead. But just showing you that it can be done.
Message Edited by muks on 08-17-2009 01:16 PM
Message 12 of 14
(1,138 Views)
On image 3, extracting the hue color plane works great - the ball is black on a white background.  It doesn't work nearly as well on image 2, possibly due to high compression.
Is the camera going to be mobile or stationary?  If it will be stationary, you could take a background image and subtract it from your live images.  Only the robots and the ball would be moving on the field.  It would be fairly simple to locate the ball in that scenario.
Bruce
Bruce Ammons
Ammons Engineering
Message 13 of 14
(1,120 Views)
Bruce,
I feel it is not going to be that easy considering that players shadow will most likely fall on the ball. It would work only when you have a really good trajectory algorithm for tracking the ball.
Message 14 of 14
(1,118 Views)
