Machine Vision
how to use IMAQ Dtect Shapes.vi
hello everyone,
                        I'm learning NI Vision, i don't understand how to use IMAQ Dtect Shapes.vi to detect shape, such as lines, ellipses, who can give me an example, thanks.
(5,065 Views)
Accepted by longzeng1981
This function uses the edges of the object and tries to fit them with different shapes such as cirles, lines or rectangles.
First you have to set the parameters to extract the edges of your objetcs. You specifie the threshold (in order to find the correct edges of your object). Then you can choose the parameters of the shape to fit. For example if you want to fit with a circle, you set the min and max possible radius.
Try this with vision assistant, it will be easier. And try it with well contrasted images too.
Regards
(5,062 Views)
thanks, I find it
(5,055 Views)
Is there any documentation as to what underlying conceptual method is being used for the detection and geometric fitting? I am performing sensitive camera calibration applications and require high accuracy, and would like to know what the program is doing under the hood.
Thank you,
AC
(4,778 Views)
