11-12-2009 02:05 PM
I installed Vision Acquisition Software 2009 on a 64-bit Vista PC with a PCIe-1429 card. When I open MAX and select the camera associated with the PCIe-1429 card, I get this messsage: "C:\Windows\System32\itss.dll is either not designed to run on Windows or it contains an error. Try installling the program again using the original installation media or contact your system administrator or the software vendor for support." (see attached screenshot). I tried both repairing and reinstalling VAS2009; I still get this error message. The itss.dll in the system32 folder is dated 11/2/2006, and is version 6.0.6000.16386.
Solved! Go to Solution.
11-12-2009 03:24 PM
Another Vista 64-bit PC, with the same board and same VAS2009 software installed, doesn't show this error. The only difference is I upgraded to VAS2009 from Vision 8.6. The itss.dll file on the other PC is the same build as the problem PC.
11-13-2009 05:29 PM
11-16-2009 03:27 AM
11-17-2009 03:19 PM
11-17-2009 05:23 PM
11-18-2009 01:10 PM
11-25-2009 07:30 PM
11-25-2009 11:10 PM
11-26-2009 11:01 PM
