Machine Vision
itss.dll error on Vista x64 when running MAX
Sorry, yesterday was a holiday here.
The version you posted appears to be an earlier version.  Mine is version 6.0.6000.16386.  Yours is version 5.2.3790.1221.  Before I replace mine, are you sure yours is compatible with Vista x64?
Message 11 of 17
(2,615 Views)
Message 12 of 17
(2,598 Views)
Thanks, but this seems like most sites on the internet that SEEM to have the file, only all links go to their proprietary software download.  I could not find a link to download the itss.dll file itself.
Message 13 of 17
(2,589 Views)
Here is the version that worked for me.
Message 14 of 17
(2,567 Views)
Thanks.  Correct version, and the errors I was getting seem to have gone away, except when I try to register itss.dll, I get:  The module "itss.dll" was loaded but the call to DllRegister Server failed with error code 0x80040201.  Anyone know why this is?
Message 15 of 17
(2,564 Views)
You probably need to run regsvr32 as administrator.
Message 16 of 17
(2,562 Views)
I've had a lot of trouble with the security garbage on Vista.  I've set both my domain and local machine accounts as administrator access.  I still run into Vista security road blocks.  Wish NI had released XP x64 drivers . . .
Message 17 of 17
(2,560 Views)
