Machine Vision
new to NI vision builder: Calculating the area of a component
Hi all,
I am new to this whole NI vision builder. I would like to  know what are the steps that need to be taken to calculate an area of a component.
Thank you
(4,051 Views)
Accepted by stealthengineer
first you have to calibrate your image and after that if you want to do your calculation automatically should use some binary action and some particle detection algorithm exist in morphology
(4,030 Views)
The Detect Objects step located in the Locate Features tab returns the area of objects. As Hatef mentioned, you must calibrate the image first if you want to get results in real-world values.
Check out the following examples:
C:\Program Files (x86)\National Instruments\Vision Builder AI 2014\Examples\Calibrate Image Step Example.vbai
C:\Program Files (x86)\National Instruments\Vision Builder AI 2014\Examples\Detect Objects Example.vbai
Hope this helps.
Christophe
(4,022 Views)
