Machine Vision
prevent auto update of camera file
Hi all
I need your help on my camera file.
I have downloaded a Kodak camera file and pasted into the data folder, where the MAX can access it.
The frame grabber I use is PCI 1424, a 32-channel one.
Since my CCD is monochromatic, I just want to get the 32-bit data and save them into an image.
However, once the camera file is accessed by the MAX, it is auto updated from version 4.50 to version 6.00.
In addition, the 32-bit data is chopped into 3 parts, each with 8-bit and corresponding to the RGB format, and the rest 8 bit data is lost during this process.
Note that this 32 bit data actually includes image from 2 output channels of a CCD board. Each channel has 12 bit data.
Is there anyway to fix this problem?
What should I do to get the 32 bit data image instead 3*8 bit RGB image?
I have attached my original and update camera files for your references. The changes are highlighted in red.
Thank you.
Xiaogang
Message 1 of 1
(3,105 Views)
