Machine Vision
"fine zoom" control
Folks - looking for a way to precisely control the zoom factor for an image in a Vision Container.  So far I only find IMAQ WindZoom that appears to work only on external windows and has integer zoom factors from 1 to 16.  Consider that the image window is fixed in size.
Something akin to MS Word Zoom control where a % zoom factor can be specified is desired:
Any thoughts?
Don
(3,530 Views)
Accepted by DonRoth
The Vision Display controls have a property called ZoomSingle which gives exactly the level of control you're looking for.
(3,524 Views)
Greg - thanks.  When I searched the 'Machine Vision' discussion forum here using the term 'zoom', I did not find any discussion on that particular property node, and although I was aware of that property node, I did not believe it had anything to do being able to specify 'SGL' or single precision float zoom.  It does, and it works very well.  Thanks again.
Don
(3,507 Views)
