I think this is a normal behavior,10-bit grayscale images are stored in the
IMAQ 16-bit grayscale type(with only 10-bit used), and bmp file format
doesn't support the16-bit grayscale type, whereas png does.
Moreover, video adapters doesn't support 16-bit grayscale too, in order to
display these images correctly, you should use the 16-bit display mapping
functions of IMAQ Vision, (see "IMAQ WindDisplayMapping.vi" in the display
menu).
You should use the "full dynamic" conversion policy , or the "downshifts"
conversion policy with 2 shifts.
Best Regards.
Jean-Christophe.
"FraserD" wrote in message
news:5065000000080000007CA70000-1042324653000@exchange.ni.com...
> I have been trying to save 10 bit depth images as uncompressed fro
m a
> PCI-1409 frame grabber. In MAX i set them up as 10 bit. In LabVIEW 6.1
> using Vision 6 i realise i have to set up as 16 bit. It doesn't allow
> me to save as .bmp therefore i save as lossless compressed .png, but
> these images are just black. Has anyone come across this before?
