Machine Vision
transitions - possible bug in VBAI 2012
I have an application in which I measure the diameter of a part in one state and then do a selection of tests in differrent states. The transitions are set on the value of the diameter (Find Circular Edge 1 - Diameter (Pixel).
If we doubleclick transition1, followed by double-clicking transition 14, transition 14 gives a result different then originally set. If however we then cancel and double-click transition 14 again, we do see the seetings as originally setted.
We've tried this with different transitions and in different programs. Same result.
In attachment the screenshot of the same transition (without changing the transition in between) after the first, and after the second double-click.
We use Vision Builder AI 2012
With kind regards,
Tom
(4,170 Views)
Accepted by declercq_tom@waak.be
I reproduced this issue and we will work on fixing it for the Vision Builder AI 2013, which we hope to release very soon.
Thanks!
Brad
(4,148 Views)
