Machine Vision
using OpenCV FileStorage in LabVIEW
Excuse me,
I read almost all the vis and cpp files, and I find one image out, it's a kinect'RGB image.
But I still haven't found how to return an Mat to the LabVIEW and display it.
Could you please tell me which project is or how to do it?
Thank you.
Message 11 of 15
(4,387 Views)
every example using OpenCV consists of passing the image (actually the image array) pointer to Mat type. Take a look at the Hough circle transformation for example. The basic idea is:
Mat inputImage(rows,cols,CV_8U,&imdata[0]);
where imdata is the pointer to your image array.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Message 12 of 15
(4,378 Views)
Thank you.
Yes, actually I have already known how to get an image from the LabVIEW and transfer it to the OpenCV Mat before,
But I still don't know how the OpenCV dll return the image to the LabVIEW.
Can the dll return the RGB image, or can only return the CV_8U image and need to combine the three channels in LabVIEW?
Best Regards
Message 13 of 15
(4,371 Views)
Accepted by SilvaShi
something like this should work:
#include <opencv2/core/core.hpp>
#include <opencv2/imgproc/imgproc.hpp>
#include <opencv2/highgui/highgui.hpp>
using namespace std;
using namespace cv;
class myclass{
public:
    Mat img;
    int readimage(){
        img = imread("C:\\Users\\Public\\Pictures\\Sample Pictures\\Desert.jpg", CV_LOAD_IMAGE_COLOR);
        if(!img.data)
            return -1;
        return 0;
myclass temp;
extern "C"{
    _declspec (dllexport) int readimage(int *img_rows, int *img_cols);
    _declspec (dllexport) int image_processing(uchar *data);
    int error_code = temp.readimage();
    if(error_code != 0)
        return -1;
    (*img_rows) = temp.img.rows;
    (*img_cols) = temp.img.cols;
    return 0;
    Mat img_to_LV(temp.img.rows, temp.img.cols, CV_8U, &data[0]);
    cvtColor(temp.img, img_to_LV, CV_BGR2GRAY);
    return 0;
and:
You can also pass the color image, but take care as OpenCV uses bgr and not rgb notation. In the past I have used 3 seperate channels, building them back in Labview.
K
Message 14 of 15
(4,363 Views)
I did it!
Thank you so much, klemen. It takes you a lot of time.
Thank you for your attention!
Message 15 of 15
(4,355 Views)
