Measure
Moving average of sorts
I'm trying to make something similar to a moving average, but I want it to average every 10 data points instead of continually moving. I'm not exactly sure what this would be called, part of the reason I'm a bit confused on what to do. I've seen several moving average functions, but again that is not what is needed. I have a very large data collection and wanted to get it to a more manageable set of data. The data is coming in the form of ones and zeros. Any guidance on this matter would be appreciated
(7,076 Views)
Accepted by sssmcd
You can review this forum post which deals with a similar requirement that you have.
Regards
Arham H
Applications Engineer
(7,060 Views)
Arham,
Thank you for your assitance. It took me a little while to test to make sure it was what I needed. It worked well.
Thanks again.
ssmcd
(7,012 Views)
You're welcome. Good luck with your application!
Regards
Arham H
(6,998 Views)
