Measure
Pressure measurement
I am new to LabVIEW and NI instruments. I am working on building an experimental setup. I need to perform pressure and temperature measurements.
I was able to do temperature measurement using thermocouples as sensor, NI9213 module (cDAQ-9174). I am not clear on how to do pressure measurement.
The pressure sensor is an Omega thin-film Pressure transducer (Link below)
https://assets.omega.com/pdf/test-and-measurement-equipment/pressure/pressure-transducers/PX1005.pd...
I have the NI9205 module. I am not sure if I can do measurement using this or I need to use a different module.
Please suggest
Kevin512
(5,386 Views)
Accepted by kevin512
Hello
I reccommned to use something similar like  NI-9236C Series Strain/Bridge Input Module.
The output of the pressure sensors are very low and they required a bidge to be measured accurately.
Read this limk, may help to take better decision
https://www.ni.com/en/shop/data-acquisition/sensor-fundamentals/measuring-pressure-with-bridge-based...
(5,263 Views)
Thank you for the suggestion.
I had been able to figure out the measurement with the suggestion
Kevin
(5,127 Views)
