Measure
Resolution of NI 9215
        The resolution of 9215 card is 0.3mV, but i only got 3-digit reading when the output voltage is over 1V, how to fix it?
        Thank you.
(6,938 Views)
Since Measure is an add-on for Excel, I can only assume that you have not set the cell format to display any more decimal places. Right click on the cell and select Format Cells>Number and change the Decimal Places control.
If you aren't using Measure, then you need to post your question to an appropriate language or hardware board. And if you post to a hardware board, provide the language that you are using and how you think you are only getting 3 digits.
(6,937 Views)
Acutually this is the first time I use your eqipment, and i didn't notice which board i went to, so I may post my question on the wrong board. Well, I have figured out how to fix it. Thank you all the same.
(6,931 Views)
