09-15-2008 11:58 AM
I need to generate some FFT data with my PCI-4462 board.
Does anyone have a .NET sample?
C#, VB, .... ?
thanks
09-16-2008
02:18 PM
- last edited on
10-29-2025
08:43 PM
by
Content Cleaner
Hello Philip,
I believe you'll find the examples you want here: NI-DAQmx, NI-VISA and NI-488.2 .NET Example Locations
You can use any of the DAQmx analog input examples that use the triggering available on your PCI-4462. You will need to use a math library to perform a FFT on the data you read in.
I hope this helps, and have a great day!
Cheers,
09-17-2008 09:10 AM
thank you
i did not know the DSP has been removed from the latest DSA boards
will do the FFT in software
09-18-2008 03:01 PM
Hello Philip,
We may have a terminology mismatch here, but as far as I know none of our DSA boards are able to perform an FFT on the hardware. If you're using LabVIEW there are built in FFT functions, but the data returned from the DAQmx Read by our DSA cards is always time domain data.
If you have a model number from some of the older hardware I'd be happy to take a look and confirm this is the case, but I believe you'll find the PXI-4472 will behave in the same way.
Cheers,
