Get any/all VISA-USB Addresses
VisaNS was the legacy .NET API for VISA that NI developed several years ago. While it is still supported, for new applications we suggest the use of NationalInstruments.Visa API that is an implementation of the IVI standard VISA .NET API.
Unlike in VisaNS where ResourceManager provided static method to get the local ResourceManager on which you would call the Find method, in the new API, you would create a new object of the ResourceManager class and then call the Find method on that object. Please see the NI-VISA .NET Help that is installed on your system for more details. You can get to it from the start menu (All Programs >> National Instruments >> NI-VISA >> NI-VISA Documentation).
Message 21 of 24
(1,769 Views)
Hope is restored. How about an example (in VB.NET)?
Message 22 of 24
(1,766 Views)
Accepted by topic author BiggyD
There are several c# based examples installed here (which can be reached from All Programs >> National Instruments >> NI-VISA >> Examples):
C:\Users\Public\Documents\National Instruments\NI-VISA\Examples\.NET\
I took a snippet from the find resources example and converted to VB.NET and used a different search string of the form "USB?*" because you are interested in finding USB resources.
Imports System
Imports System.Collections.Generic
Imports Ivi.Visa
Imports NationalInstruments.Visa
Module Module1
    Sub Main()
        Using rm = New ResourceManager()
            Try
                Dim resources As IEnumerable(Of String) = rm.Find("USB?*")
                For Each s As String In resources
                    Dim parseResult As ParseResult = rm.Parse(s)
                    System.Console.WriteLine(s, parseResult.InterfaceType)
            Catch ex As Exception
                System.Console.WriteLine("Exception" + ex.Message)
            End Try
        End Using
        System.Console.ReadLine()
    End Sub
End Module
Hope this helps.
Message 23 of 24
(1,761 Views)
Uh,oh.... You did it!  You're my hero!  Now get NI to put it in their manual.
Good job. Thank you so much.
Dave
Message 24 of 24
(1,754 Views)
